Interrupts
MacGeek117
I'm just starting to work with SX/B, and I can't seem to find out how to cause an interrupt by triggering the RTCC pin. Could I please have some help?
RoboGeek
There are 10 kinds of people in the world,
those that know binary and those that don't.
Formerly bugg.
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
The RTCC register can be configured to count pulses on the RTCC pin.
When then RTCC register overflows (goes from 255 to 0) that is what causes the interrupt.
This is configured by using the OPTION register.
If you truely want a pin to cause an interrupt, you must use one of the RB pins and set it up to generate an interrupt.
I can't tell you how to do it right off the top of my head because I very rarely use triggered interrupts.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Those that would give up freedom for security will have neither.
But all of this can be done more straightforward by using interupt on Port B option.
·1+1=10
Post Edited (Paul Baker) : 11/17/2005 7:45:24 PM GMT
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Jon Williams
I have many times, mostly with my head. I have·the SX/B·Online Help open·right now-I guess I should tell you something. I don't understand. It's as simple as that. I don't understand. I need to learn. Please, teach me!
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 11/17/2005 11:52:31 PM GMT
·1+1=10
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
starting on page 108 (page 118 of the pdf), pay attention to the code presented on page 112 and 113 (122 & 123 of pdf), you'll see they are dealt with bytewise (ie WKED_B=$FF WKPND_B=0 etc.).
·1+1=10
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Seriously, your wasting your time (and ours) asking if a program works, when you don't have any hardware.
It's like trying to teach someone to drive without a car.
I would read the WHOLE manual, then read the WHOLE datasheet, then read the entire SX/B help file, then go back and re-read everything again.
I'm being serious. I bet I've read the SX-Key manual 12 times or more, pretty much cover to cover. And everytime a little more of it sticks inside my brain.
That way when you do get hardware you will be ready to start cranking out the code.
If you have questions about the SX documentation please ask away.
I'm not trying to discourage you, I can tell your really into this stuff, but there is alot of info in those documents, and reading them is not time wasted.
Bean.
·1+1=10
RoboGeek
There are·3 kinds of people in the world,
the dreamers, the do-ers, and the "Oh, what's this button do"-ers.
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
·1+1=10
You can find this information in the SX28 datasheet on page 12.
Now, concerning your trouble with SXSim, I have no idea what happens to the "Commands" window. When you simulate a list file, say "TEST.LST", and exit SXSim, or select another LIST file, SXSim saves important session data in a *.SIM file (TEST.SIM in this case), including the positions and sizes of the various windows. Maybe, the position information for the Commands window in the SIM file got corrupted by some reason, causing the Commands window beeing positioned somewhere outside your screen resolution. Simply delete the SIM files, and give it another try. Without a matching SIM file, SXSim will reset to the defaults, including the position of the Commands window. Please let me know if this works for you.
Greetings from Germany,
G
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 11/19/2005 12:50:05 AM GMT
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Jon Williams
