Need help with memsic sensor code.
SN96
I was looking at this code and it all makes perfect sence except one variable "moTimer". In the code, in the main routine, moTimer is reset to zero, if moTimer is less than AlarmLevel. AlarmLevel is a constant set to 5, so how can moTimer ever be grater than 5 if it is reset to zero? What am·I over looking?
"Don't always think outside the box, sometimes thinking inside the box is more practical and simple."
' ========================================================================= ' ' File...... MEMSIC2125-Motion.BS2 ' Purpose... Detects continuous motion for given period ' Author.... Parallax (based on code by A. Chaturvedi of Memsic) ' E-mail.... [url=mailto:support@parallax.com]support@parallax.com[/url] ' Started... ' Updated... 15 JAN 2003 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' Monitors X and Y inputs from Memsic 2125 and will trigger alarm if ' continuous motion is detected beyond the threshold period. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Xin PIN 8 ' X pulse input Yin PIN 9 ' Y pulse input ResetLED PIN 10 ' reset LED AlarmLED PIN 11 ' alarm LED ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- HiPulse CON 1 ' measure high-going pulse LoPulse CON 0 SampleDelay CON 500 ' 0.5 sec AlarmLevel CON 5 ' 5 x SampleDelay XLimit CON 5 ' x motion max YLimit CON 5 ' y motion max ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- xCal VAR Word ' x calibration value yCal VAR Word ' y calibration value xMove VAR Word ' x sample yMove VAR Word ' y sample xDiff VAR Word ' x axis difference yDiff VAR Word ' y axis difference moTimer VAR Word ' motion timer ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Initialize: LOW AlarmLED ' alarm off moTimer = 0 ' clear motion timer Read_Cal_Values: PULSIN Xin, HiPulse, xCal ' read calibration values PULSIN Yin, HiPulse, yCal xCal = xCal / 10 ' filter for noise & temp yCal = yCal / 10 HIGH ResetLED ' show reset complete PAUSE 1000 LOW ResetLED ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO GOSUB Get_Data ' read inputs xDiff = ABS (xMove - xCal) ' check for motion yDiff = ABS (yMove - yCal) IF (xDiff > XLimit) OR (yDiff > YLimit) THEN moTimer = moTimer + 1 ' update motion timer IF (moTimer > AlarmLevel) THEN Alarm_On ELSE moTimer = 0 ' clear motion timer ENDIF LOOP END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- ' Sample and filter inputs Get_Data: PULSIN Xin, HiPulse, xMove ' take first reading PULSIN Yin, HiPulse, yMove xMove = xMove / 10 ' filter for noise & temp yMove = yMove / 10 PAUSE SampleDelay RETURN ' Blink Alarm LED ' -- will run until BASIC Stamp is reset Alarm_On: DO TOGGLE AlarmLED ' blink alarm LED PAUSE 250 LOOP
I didn't go through the program logic, but did you miss this line of code:
There is also an implied AND (I believe) once you reach the subsequent IF statement, listed below:
Additionally, every ELSE is "connected" ONLY with the immediately prior IF (unless PBASIC does something non-standard). Ergo, if BOTH conditions (implied AND noted above) are NOT met, THEN and ONLY then will:
moTimer = 0
Bruce Bates
IF (xDiff > XLimit) OR (yDiff > YLimit) THEN ADD 1 to moTimer, but only add 1 if eirther condidion is met (OR), not both.
If xDiff or yDiff are with in limits, moTimer will = 0. Even if moTimer had a value 1,2,3 or 4, the ELSE statement would make moTimer = 0.
moTimer can only increment in value if xDiff or yDiff are grater than the limit values.
I’m not saying I'm right, I'm just explaining my interpretation of the code. This is how it works in my mind when I read it.
Please forgive my ignorance.
·· You are correct.· If either limit is exceeded, a counter (moTimer) will increase until it reaches the alarm level, at which point an LED will blink.· At this point you would need to reset the BASIC Stamp.· If, however, the device is back within limits before the counter reaches alarm level, moTimer is reset (It's not cumulative).
csavage@parallax.com
FWIW, the "OR" evaluates to True if either OR BOTH conditions are true. The comparison you referred to (if either BUT NOT both) is "XOR" (exclusive OR).
I still don't understand how moTimer can increase in value if the·ELSE statement tells it to reset to 0.
I understand the code is correct, i just don’t understand the logics.
Thanks for trying to explain. I will figure this out on my own.
·· You are testing a condition.· While this condition is true the moTimer variable is updated.· When the condition is NOT TRUE (FALSE) then the code below ELSE is executed.
It's like, "IF THIS HAPPENS, THEN DO THIS OR ELSE DO THIS OTHER THING..."
So one or the other will be executed depending on whether or not the result of the operation was TRUE or FALSE.
Main:
· DO
··· GOSUB Get_Data····························· ' read inputs
··· xDiff = ABS (xMove - xCal)················· ' check for motion
··· yDiff = ABS (yMove - yCal)
··· IF (xDiff > XLimit) OR (yDiff > YLimit) THEN·· 'if one or the other·or both is TRUE then add 1 to moTime
····· moTimer = moTimer + 1
····· IF (moTimer > AlarmLevel) THEN Alarm_On· 'if moTimer > 5 then·do Alarm_On·- otherwise moTimer = 0
··· ELSE
····· moTimer·= 0·' clear motion timer····'<-- When this is executed,·moTimer went·from 1 to··0
··· ENDIF
· LOOP '<-- Do the cycle all over again with moTimer = 0
· END
So the above code looks as though moTime would flip flop from 1 to 0 to 1 to 0 all day long. The only way I can see it working is if the ELSE statement is not executed in a FALSE condition, keeping the value moTimer·equal to·1, then 2, then 3, untill it reaches 5 at which time Alarm_On would be executed.
Sorry for the head ache guys. I know I am being a real pain in the @#$!
and then they are not met following that (so the timer gets cleared)
If neither of those conditions are met, then the moTimer will stay 0.
Ryan
Corrected 'clear' condition- thanks Jon, was thinking ahead of my fingers...
Ryan Clarke
RClarke@Parallax.com
Post Edited (Ryan Clarke (Parallax)) : 11/18/2005 12:22:52 AM GMT
Ryan
Ryan Clarke
Jon Williams
My error in following the logic was not realizing the ELSE statement belonged to the:
"IF (xDiff > XLimit) OR (yDiff > YLimit) THEN moTimer = moTimer + 1 " line of code.
I was originally reading it that the ELSE command belonged to:
"IF (moTimer > AlarmLevel) THEN Alarm_On " line of code.
She told me to pay attention to the indentation of the commands to follow the code, something I forgot to do. It all makes sense now. Champaign anyone?
