Question regarding CMUcam
Hi guys,
········ I have a boe bot which i would like it to go from point A to point B with the help of two IRs and a Cmu cam. Point B will have A Red beacon with IR tranciever. The problem is the I can't dump the frames from the CMUcam in the gui. Everytime i use the gui and i open the port then send rs "reset" the GUI program·halt up and i have to close it. Any ideas of how i can see the pictures from the CMUcam in my pc before i start coding??
If you are using the Parallax version, you can't without modifying the CMUcam, as far as I know. The Parallax version is limited to 9600 baud, and the CMUcam needs to be running at 115k to dump frames at full res. I have started but not finished writing some code for the hydrogen robot to do so. It's been on the back burner for a while now. The modification is easy, but will certainly void the warranty. All you have to do is unsolder the jumper across the baud rate selection pin. While Parallax modestly claims the p40 won't reliably communicate at that speed, mine does so no problem. However, YMMV!!
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
