Instead of a DAC, here's something to consider.
The attached image is adapted from the upcoming Process Control text (to replace Industrial Control).
By PWMing P2 you can control the output of the op-amp buffer from about 0.5V to 5V, and the RC filter only needs to be refreshed every couple seconds.
The RC filter will give an average voltage of the PWM value, which will be buffered by the op-amp (LM358) for driving a small load. It has an 8-bit resolution based on the PWM instruction
PWM 2, 128, 100 'output would be approx 2.5V.
Sorry, haven't figured out how to insert images yet....
Try a DAC0806 or DAC0804.· They're 8-bit jobs, but for a voltage out you'll need to add the current-to-voltage amp (the complete circuit is in the datasheet/s.)
They're not the last word in DAC'ing, too slow to do Hi-Fi audio or anything, but they're easy to work with, and understand, and not uber-finicky like.
-Martin
Martin Hebel
Electronic Systems Technologies
Southern Illinois University Carbondale
Personal Links - ·Lot of BASIC Stamp info
and
SelmaWare Solutions
StampPlot Pro Version 3 Release 4
Graphical Data Acquisition for your Micro and Imagination!
Now allows additional controls to be added, or developed.
www.jameco.com/wcsstore/Jameco/Products/ProdDS/14912.pdf
Jameco has DAC0808 (MC1408) for less than $2.
