Sharing LTC1298
Is this possible. I am running out of I/O for this project and I am hoping that I can share Inputs to a LTC1298. I am attempting to use two LTC1298 for input for a setpoint. They will be working independently of each other until setpoint is reached. Ok, Is the following feaseable or back to a 40 pin stamp.
CS········· PIN· 0····························· · ' A/D CHIP SELECT
CLK········ PIN· 1····························· · ' A/D CLOCK
*DIO_N0····· PIN· 2··························· ' A/D DATA I/O
CS1········ PIN· 0····························· · ' A/D CHIP SELECT
CLK1······· PIN· 1····························· · ' A/D CLOCK
*DIO_N1····· PIN· 3··························· ·' A/D DATA I/O
As You can see I will not be using the same Data I/O....
Guido
Guido
·· On SPI devices it's the Data and Clock lines you do want to share.· The CS lines are what need to be separate.
csavage@parallax.com
Thank You very much, If I am understanding you then this should do the Trick.
CS PIN 3 ' A/D CHIP SELECT
CLK PIN 1 ' A/D CLOCK
DIO_N0 PIN 2 ' A/D DATA I/O
CS1 PIN 4 ' A/D CHIP SELECT
CLK1 PIN 1 ' A/D CLOCK
DIO_N1 PIN 2 ' A/D DATA I/O
