Rs232
Ivan
I am using the Javelin in the Stamp PLC and I would like to use the same PC interface link used·when programming, for data exchange with the PC.· The basic stamp permits this - by·setting the pin param to 16 (or something like that?). Can this be done with the Javelin and·how? Also how good is the coms circuit, am I better of using· a max232 or something - this would negate my reason for choosing the Stamp PLC!·
I am new to stamps and to Java so please keep it simple!
http://groups.yahoo.com/group/JavelinCode/files/JideTerm/
JideTerm.exe is the command line version.
JideWin Terminal is the windows version.
After you have downloaded a program to the javelin, close the Jide program
and start the terminal program of your choice. You can log messages to a file
and send keystrokes and textfiles to the javelin.
regards peter
PC app. is no problem, its the Javelin side of things I need help with. The uart vp requires me to specify i/o pins, but Sout and Sin are not avaiable (or are they).
System.out.print() or System.out.println() or you
can use my Format class method printf() like Format.printf()
http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/util/text/
Class Format allows you to easily print chars, strings, decimal, binary, octal and hex values.
It also allows you to parse input.
To receive data from pin SIN, you use
Terminal.byteAvailable() to check if there is any data.
Terminal.getChar() to read one character at a time.
My adapted terminal class Terminal.java
http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/core/
also allows you to read an entire string, method Terminal.getString()
Since the javelin SOUT and SIN pins have a special protocol you cannot use
these pins to communicate with any device, unless that device is programmed
with the javelin protocol. My terminal programs (earlier post) are.
regards peter
Post Edited (Peter Verkaik) : 11/16/2005 4:39:45 PM GMT
http://forums.parallax.com/showthread.php?p=555000
To emphasize the use of SOUT and SIN pins:
If you want to communicate with an external device that has no knowledge of
the javelin protocol, you must create a serial connection using I/O pins and Uart VP's.
regards peter
