BS1USB and SERIN & SEROUT
Basic Stamp New comer here...
Is it possible to use the USB interface to get and send data between my BS1USB and computer, or do I have to make a serial connector from one of the pins?
If so, how could I go about using Hyperterminal to receive and send commands/information to my BS1USB?
Thanks!
-Nick
Thanks!
-Nick
Consider the USB as simply a serial connection. Even in your device manager you'll see that a COM port is mapped to the device. This being the case, anything you could do serially will apply here...
Ryan
Ryan Clarke
RClarke@Parallax.com
Do you know of any resources on how to get and send information/commands with the Basic Stamp I?
Nick
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv20.pdf
Per Ryan's comment, the FTDI VCP drivers make the com port used by the BS1-USB look just like any other serial port.· Note that there is no way to send serial data to the USB-BS1 via the USB port; this is possible only with the BS2.
Jon Williams
Now you say I can't do it via the USB port, but can I use one of the PINs and use an actual serial port?
I'm assuming the answer here is yes... hopefully
Jon Williams
