PINK tips, tricks, help and hints
Prior to document revision, I will post general information on the PINK module here.
Ryan Clarke
RClarke@Parallax.com
Ryan Clarke
The possibility of allwing this port to be user defined is being discussed.
Those connecting an SX to the PINK need to make sure they allow the module sufficient time to get on the network before sending it data or commands- one way of accomplishing this is to poll bit 0 of the Nb_varST (the status register)- bit 0 will have been set by the PINK when a network connection has been established.
Ryan Clarke
Steve
