Distance / Range finder
Hi everyone,
I plan on purchasing a distance sensor for my robot, but I don't know which way to go: DIRRS+ or Ping)))
They are of comparable pricing so it's tough.· Can anyone here give me a quick comparison and advise on which is better (easier to program, more accurate, less interference, etc.)
Thansk for the info.
I read a "white paper" that a High School student did comparing and contrasting accuracy of sonar vs IR.· Here is the link --> http://www.elqc.com/will/willg7sf.pdf
Look at page 32 for the conclusion.
Thanks again for your help.
When comparing any sonar to any IR sensor you have to look at the application that you are using them for. For instance Sonar would probably not be your best best for detecting objects really close to your robot where as IR could. If it is an outside robot, you have tons of IR interference such as the sun. I am sure that some IR sensors are more apt to work differently than others but is still something to consider. Even sonar has a blind spot. If you are looking at rounded objects, the sound signal that is produced by the sensor might reflect off in a different direction and not make it back to your robot to report that there is an obstacle in the way.
These are just some things to consider.
Alex Burke
burke@ajbrobotics.com
"The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment." ~Warren G. Bennis!
