Very VERY Thin PCB?
I there·a company tha makes very thin PCB's that i can solder some SMD LEDS to that i can get to follow a contour?· I have a very cool idea in mind for this if i can find that..· thanks
It's Only A Stupid Question If You Have Not Googled It First!!
·1+1=10
Rick
-dave
This is not a sig. This is a duck. Quack.
Skip the circuit boards and just draw the circuit on the wing itself using a conductive ink pen normally used to repair circuit board traces. Or use the sticky-backed copper tape sometimes used in making stainglass windows. Not sure how you could connect the LEDs. Is there a conductive glue? Maybe the aluminum filled epoxy?
Make a matrix with wires on the top surface running fore and aft, and the ones on the bottom running side to side, with the LEDs oriented more-or-less vertically in between.
Rick
-dave
Here's a link to some:
www.smarthome.com/84722.html
I know the price is high, however look at the idea.... This same style material is used in doll houses (probably started out here originally), for running fake 110VAC outlets to the doll houses. I bought a 100' roll from my local hobby shop (HobbyLobby) for something like $12.
So, look around in your local hobby shop for this stuff, probably in the doll houses.
The wire is copper, and it's got a high bend radius. No doubt it could bend to around a pencil. It's got a piece of adhesive double sided tape, then the copper strands are layed in, then a piece of single sided adhesive plastic to cover the top. So, you peel off the underside and stick it on, then it's smooth. Once painted, it's hard to tell it's there.
I use it to install alarm contacts on windows.
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn't exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
·1+1=10
Small squares of Copper tape might be a good idea for the LED pads as well. Easy to solder to, and they'll hold the LEDs in place while painting. I'm just brainstorming here, but it seems like this is the most plausable way to get it done quickly and inexpensively.
-dave
