5v regulator connection on BOE
Hello,
I am a newbie here and have a simple question. From what I have read supply voltage going into vin of·the bs2 needs to be a·regulated 5v. I am trying to replicate the Board of education regulator circuit in a smaller package for a project. From the schematic of the serial board of education it looks like the vin from the battery goes straight in to the vin of the bs2, before the 5v regulator.·Is that correct? ·I know this is probably a silly question, but I wanted to make sure that I did not damage my stamp. I have attached the schematic. Any assistance would be great.
pdf
24K
http://www.parallax.com/html_pages/tech/faqs/fctl_info.asp#VIN%20Pin%20use
csavage@parallax.com
So, if all you need is another 40 mA or so, you can use the on-BS2 voltage regulator.
If you decide to have an external regulator (which is a good idea, by the way) then you feed the output of the external regulator to Vdd of the BS2, and leave Vin disconnected.
In either case, make sure the 'ground' line is connected to Vss. Vss is the 'ground' for the BS2, regulators, and signal ground for the SERIN/SEROUT/DEBUG signals.
Jon Williams
I have purchased the one that is in the schematic for the BOE, are there others that are better?
Alternatively, get a low drop out switching regulator which wastes much less in the regulaton process [noparse][[/noparse]80% efficeient as compared to 70% efficeient.] Of course, if the switching regulator is not low drop out, it seems that the trade-offs offset each other. {i wish I could spell effic....????}
From what I have read, I think I need some capacitors in my regulator circuit. Is that true? If so how do I figure out what to use?
I took electronics tech in school 13yrs ago but never used it, I'm kinda blowin out the cobwebs. Any tips would be great, things have come along way since then.
