ExpressPCB Help
I am just learning the Express PCB software and seem to be stuck on the first try.
I made a schematic, saved it, went to ExpressPCB, inserted the components, Linked the schematic. The pins turn blue like they should to highlight the net connections but I don't seem to know how to insert a SYMBOL in the PCB program so I cant hook up wires to symbols like Gnd for example. So how do I do that?
Sid Weaver
Do you have a Stamp Tester yet?
Sid Weaver
Sid Weaver
I would think the Ground , the +9volts and the Port that I have as symbols should have connections or pads that I need to put in the PCB
program so I can wire all the pads to all the components correctly.
Jon Williams
