WAAS GPS quick questions
What is the highest accuracy one can get from GPS? I had seen some websites offering WAAS with 3 cm resolution, but others say 3m, so maybe that was a typo...?
Ben
Ben
If you get a DGPS ($$) you'd get finer accuracy....but that's too much money to know my MPG down to the n'teenth decimal place! [noparse];)[/noparse]
Hey Forrest, do the surveyors use a single DGPS to reference their main survey tool and then all their 'flags/reflectors' are referenced to it?
Steve
A friend of mine is in the mapping business and so I asked him.
1) Accuracy standard GPS.
2) Accuracy of DGPS.
D(ifferential)GPS is, if setup and operated correctly, can easily get you to accuracies less than 1cm. Essentially you are running 2 GPS units, one set up over a known location, the other being the rover unit. Software then removes the effect of the ephemera, assuming that the effect is the same for both instruments. This is either done real-time or via postprocessing.
DGPS techniques can also be used using one rover unit and a publicly or privately available reference beacon.
3) Is there a difference between DGPS and the WAAS?
Essentially this accuracy gets you close enough to see things or have a higher accuracy localized service take over.
DGPS uses "local" beacons to apply more area specific corrections. This will drive the accuracy 3 meters at worst to sub cm at best. Most probably will give you sub decimeter accuracy.·DGPS can use publicly available beacons from the Coast Guard, state or county services or private subscription services. A public network of beacons called CORS is probably the best source of such signals. Set up by the NGS (National Geodetic Survey). This is set up for uses that require higher accuracy than beeing able to see the object you're trying to locate.
Here's· at least one link you can mine for info:
http://www.edu-observatory.org/gps/
And of course, there's always the NGS for CORS:
http://www.ngs.noaa.gov/CORS/
And the FAA for WAAS:
http://gps.faa.gov/index.htm
Many thanks to Peter Moreau, Houston TX
John J. Couture
San Diego Miramar College
