Ultrasonic Range Finder Materials Question
I'm working on a project, that I'm thinking of using the Ping))) Range finder, and I'm wondering if someone knew two things that I can't seem to located in the cut sheet.
- I'm looking to measure the distance TO water. Does anyone know if I can do this with this sensor, meaning, does water echo sound waves decently·enough for a device like this to work okay? (Abviously staying withing tolerance of 3 meters)
-Again, because I'm using distance to water, in the event of a screw up, has anyone tried using a film or something over the sensor to protect it (I was thinking a thin layer of plastic wrap), but is there any material that will protect against water but still allow the PING)))·to properly send and receive.
Thanks!
Mike.
Thanks!
Mike.
Oh, and FWIW, I was able to sense the distance to the surface of water suspended above the sensor (i.e. the sensor on the desk facing "up" and the water surface being moved up and down above the sensor). Can you figure out how I did that?
As an experiment I put a piece of clear "scotch" tape over the sensors. The PING sensor immmediately stopped responding to any object (i.e. I only see values of 10,000 or higher). I then tried putting the tape over the "left" sensor only, and the unit would respond to items placed within 3-5 inches, and then only intermittently. If I cover the right sensor, it only changes output if an object comes within 1-2 inches of the PING)) unit, again, intermittently. So, the protective film would have to be thinner than regular "office" style clear tape. I would imagine covering the sensor in any way would really screw up the device calibration as well.
Anyway, I hope this is useful info.
Vern
Post Edited (Vern) : 11/11/2005 10:53:36 PM GMT
Like already stated before you should be able to measure the water just fine.· Although I have never tried it my self.· I am not sure what you could put in front of the Ping that would protect it and not cause an echo.· Anything flat and smooth will create and echo, even if its very thin.
Doug P
Parallax Engineering
