Newbie question on WAM kit - servo tutorial
Hello Forum,
·· I hope this is the right place to ask this question. I have recently started going through the servo tutorial in the WAM kit and I noticed that the schematic shows that the Parallax standard servo is powered from Vin rather than Vdd.·It·also includes a warning not to use the·Parallax·continous rotation·servo(which I recently ordered)·as the circuit may damage it. I looked up the specs on both servos and they both·carry ratings of 6 volts. So now I'm puzzled by a few things. Why can't I use both servos for these example·circuits if they have the same rating? Why am I hooking up the servo to Vin instead of Vdd? Isn't Vin a direct connection to the 9 volt battery -·which is over the power rating of the servo? And finally, what would happen if I used Vdd to·power the servo? Would this damage the board. btw -·I am·doing the projects on·the·homework board. If anybody could help with these questions it would be much appreciated,
Thank you!
-Charles
Thank you!
-Charles
I find that a 9v works great to power the Stamp, but I use several AA batteries (4 to 6) to power the servo (use 6 AA's if they are Ni-MH rechargeables since they only provide 1.2 volts, as compared to a standard AA battery that provides 1.5 volts).
csavage@parallax.com
