Baud rate question.....
Another question for ya.....
I'm having trouble getting requested data from a conected unit.· The device runs at 10400 baud, b-bit, no parity, non-inverted (supposedly, tho they aren't sure on the last one).· From the help file, I calculated a value of 76 (assuming it's non-inverted) or 16460 (assuming that it's inverted).· But I'm getting nothing.· I've run it with and without a 22k-ohm resistor on the Input leg, and there's no difference.· Any ideas?
Thanks again,
Adam Lambertus
Thanks again,
Adam Lambertus
csavage@parallax.com
You have to do some creative things, me thinks, to get it to read.
Parallax sells their CANBUS controller that, I THINK, covers ISo-9141.
I picked up an ODB2 Interface IC from these guys www.elmelectronics.com/
Sadly, I was only able to interface to it from the pc end...but never did have the time to connect it to my jeep to get some readings.
They have some Circuits in their PDF wrt connecting their IC to it.
I think the IC you want to look at is the ELM323.
Steve
I've recently bought a MAC and don't have my Parallax stuff on it yet!
I mean, if you know its baudrate and it's parameters (N81..etc..) then calculating for TRUE or Inverted is no big deal, you would just flip the numbers if you weren't getting anything.
have you tried connecting to the rs232 converter thing with a terminal program first? Hyperterm or Procomm?
Are you running the converters TX pin in to the right Stamp input pin (or PC RX pin?)?
OH...and DO keep that 22kohm resistor in there to be sure you don't kill the stamp pin.
Are you sure that the levels coming out of the converter are RS232 levels? or are they dumbed down 5volt levels?
If you have 5volt levels, then the 22kohm resistor wouldn't be needed, and just might prevent a proper data path!
Steve
Soooo.....I'm guessing that I need to recalculate the resistor used, so as to bring it to 5volts.....but that -8volts bugs me......
Can the board use a -8 (or -5) volt signal???
-12V on the Tx line is usually the voltage level that it sits at while it's idle.
-12 corresponds to a logic 1 (which is usually a +5volt level which is why we say that rs232 is inverted in the baudmode)
+12 corresponds to a logic 0 (which is usually a 0volt level.....).
The stamp pin only sees things above and below the threshold level (I think it's around 2.25volts, but someone can correct me)...
so if the stamp sees a voltage on its pin that is over the threshold, it assigns it as a logic 1 (or high)....if it sees a voltage below the threshold, it assigns it as a logic 0 (or low).
Again, these voltage levels are opposite when comparing TTL and rs232 (so TRUE and Inverted).
The stamp should see the -8 as a logic 0 and it would see a +8 as a logic 1.
The resistor is there to limit the amount of current going to the stamp so it doesn't fry...there are built in clamping diodes on the stamp (to each pin) that will clip the voltage to 5volts....so with the 22kohm resistor you should be just fine!
Steve
MAC stands for Media Access Controller - a network interface
Mac stands for Apple Macintosh
Never heard of someone buying a new MAC address....agreed, the format of the word may be off, but maybe I assume too much that people will read it in context!
Steve
- Stephen
