Studded Rods
Can someone explain to me how a studed rod works, I have been told that it is basically a ball and socket joint. What type of rod ends best replicates the ball and socket configuration? I always assumed that this was a huge problem still unsolved in engineering. Thanks!-Hacker
Go to http://www.rod-ends.com/·for more types and examples.
"Don't always think outside the box, sometimes thinking inside the box is more pratical and simple."
John R.
8 + 8 = 10
·To get somthing like this:
The devices shown are called "shperical rod ends" (and probably other things, depending on where you are from and what industry) and have a ball with a hole through it. This ball rides in the carrier, and pretty much pivots the same as a ball and socket joint (able to revolve about the pivot, and a limited amount of "off axis" pivoting).
The hole is for a pin, screw or bolt to go through to attach the rod end. This is the big difference, where a ball and socket "snaps" over the ball, you need to put a pin or other fastener through the hole of these guys.
John R.
8 + 8 = 10
~Jeff
P.S. This is what this part of the alphabet would look like if "Q" and "R" were eliminated.
