Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Question — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
Question
Spencer
17
2005-11-11 11:35
edited 2005-11-11 12:02
in
General Discussion
I was just curious to know how difficult the transition is from a BS2 to a Javelin is. I am fairly familiar with the basic stamp, but have no experience in Java at all, some C++ though. Thanks.
Peter Verkaik
3,956
2005-11-11 12:02
I used to use basic stamps (still do sometimes) but when the javelin came out
I switched. I didn't know java, but I did know C, not C++.
Not knowing (sun pc) java is an advantage I think if you start with the javelin.
If you know C you should be able to learn its syntax within 3 days, I did.
Many BS2 commands are present in the javelin, some timing differences
and different syntax (though the names are identical, like shiftIn and shiftOut).
regards peter
Sign In
Register
to comment.
regards peter
