Having a problem with timing
oberoc
I am using the Javelin Stamp plus the eb500 bluetooth board to transmit some signals to
a basic stamp board.
My calling code:
response=TxRx("con " + address,"cmd");
response=TxRx("get_net","data");
if (response.toString() != null) {
if (MyNetwork.equals(response.toString())) {
address=null;
} else {
response=TxRx("set_net " + MyNetwork,"data");
response=TxRx("dis","cmd");
My TxRx Method:
static String TxRx(String sendString,String mode){
StringBuffer oneBuf = new StringBuffer();
char tempChar;
if (mode == "cmd") {
System.out.println(sendString);
if (CPU.readPin(CONNECT_STATUS) == true){
if (hardbufMode() == false) {
System.out.println("Failed: Switch to buf mode\r");
txUart.sendString(sendString);
txUart.sendString("\r");
if (Expect.string(rxUart, "ACK\r", EXPECTDELAY)){
while ( (tempChar =(char)rxUart.receiveByte()) != '>' ) {
oneBuf.append(tempChar);
} else {
System.out.println("Blah");
return oneBuf.toString();
And the hardbuf method
static boolean hardbufMode(){
CPU.writePin(COMMAND_PIN,false);
if (Expect.string(rxUart, ">", EXPECTDELAY))
return true;
else
return false;
What is the problem is that when my program gets done calling sending get_net to the
TxRx method, I send a dis to disconnect from the remote board. But, in the hard buffer
method, the Expect.string(rxUart, ">", EXPECTDELAY) is not coming back with a > like it
supposed to. Now, I call the TxRx function with the cmd parameter earlier in the program
with no problem. I believe that it is some kind of timing issue. Could anybody shed some like
on this?
-Tino
My calling code:
address=null;
} else {
My TxRx Method:
char tempChar;
} else {
return true;
else
return false;
on this?
-Tino
http://forums.parallax.com/showthread.php?p=469259
Compare your transmission code with the code in that thread.
regards peter
Looked at his code. The only statement I was missing was the CPU.delay(2000). I put that in and no luck. I did however get a stack trace. Which I have include here.
Here is the offending code:
CPU.delay(5000);
return true;
else
return false;
From debug - static variables
stamp.core.CPU pin #6 0x0040 '.@'
rxUart.buffer is a bunch of bluetooth addresses, >, and ACKs
Any suugestions?
-Tino
txUart.sendString("\r");· //this uses doublequotes
by
txUart.sendByte('\r');·· //this uses singlequotes
the character '\r' is 13 decimal (CR) and I guess it makes no difference
except that sendByte is faster code (saves time)
regards peter
Lower baudrates requires less cpu background time and the
margin error in baudrate between sender and receiver is better.
regards peter
