Snake Bot
I am attempting to build a robotic snake for school but being a mechanical person I am somewhat at a loss of what to do for the electronics.· My system contains 14 body segments and one head segment.· Each body segment contains 2 servos and 13 sensors (they can be multiplexed if necessary).· In order to control this and collect all the data, I expect to have a processor for each body segments as well as for the head.· Right now I expect the head module to collect and send up to 8 bytes of unique data·to/from each body processor.· At all times the segments also need to maintain control of their servos.·
I am looking at the BS2P the SX and the Javalin versus a separate processor, likely a PIC16 or some close variety.· Though I am not certain, initial testing suggests that I may need interrupt capability and possibly communication buffers.· My main concern is communication.· I will be running the system between 10-20Hz and do not want the system to hang because a segment has not received its updated commands.· Is it possible to get bidirectional communication working between 15 Stamps?· Can anyone suggest a good processor, resources or provide other bits of wisdom?
Thanks in advance!
-Amit
Thanks in advance!
-Amit
You have 15 body segments and 2 servos for each segment you can controll all of this with one stamp using buffers for additional io lines (many posts on adding output and input output pins in this forum.
Seems to me your servos would not all be moving at the same time for a snake as each segment cascades to the next one but i would say you need more power than the basic stamp 2 unless you can read your sensors and update data during the pause phase of the servo driving routine. Not saying with some really good logic a bs2 could not be used to do this but not knowing how much data and what kind of sensors you are planning to use makes that determination impossible.
Ryan
Ryan Clarke
RClarke@Parallax.com
I would invision 30 or so micro motors with tiny wheels along the bottom of 30 segments that each have perhaps a 15 degree movement sideways, cascading the motors from front to back a small power surge on each one might give you a snake like movement as each motor wheel would pull the remaining sections forward till a few sections were at 15 degrees and then as the motors cascade to the back of the snake the front sections would pile up in the S type curves you are looking for.
Pure speculation of course off the top of my head.
Ryan
Ryan Clarke
"i would say you need more power than the basic stamp 2 unless you can read your sensors and update data during the pause phase of the servo driving routine."·· From what I understand the Javalin can output a PWM signal in parallel with other tasks.· If this is true then it seems like an attractive quality.· Is this true for the SX as well?
As for the data, it will mostly be unsigned·1byte·from potentiometers, strain gages and current sensors.
The power will be onboard.· I will be using High Discharge Li-Po 330mAH batteries.· They are fairly light (~30g).· Each segment is about .6lbs total.· I expect to have a run time of about·5-10 minutes from full charge if running at full speed.
I have seen the one with treads. I believe that the one you are referring to is the OmniTread being done at UMich Ann Arbor. Their robot is very interesting in that it has a unique design and is very powerful and stable. I was trying to get something though that is smaller and lighter. Also one of my goals is to imitate snake locomotion as closely as possible. While treads or wheels do have their benefits, they are less biomimetic.
·1+1=10
·1+1=10
