basic stamp 1 rev DX
The wiring terminals are differant on the dx compared to the D which I was used to I have a 7.5 V transformer outputting 10v dcwired in to the battery terminals with an adapter I am triggering·ssr relays just like I have on the rev D I have the GRN wire going to the GRN terminal on the ssr.However I am not getting any out put from the stamp. The program is a simple pin out pin off routine for 4 pins. I am using term 2 for the GRN the first 3 pins on the bs are marked Vss. Am I wrong?
Jon Williams
