Hmm. I'm assuming it passes the loop-back test, and chip found test.
This can happen if you write to the EEPROM using a BS2 program, that writes again and again and again... The EEPROM is good for about 1e6 writes, which is a long time if you reprogram it once a minute, but not a long time if your program writes to it once a millisecond.
Yes, it passes the loopback test and the IDE finds the stamp.
I hardly ever use the BS2. I've spent the last 6 months toying with the Javelin Stamp. Now, Ive been back for 2 weeks, going through the Robotics! book from Parallax learning how to use a BS2.
Is this a permanent error? If not, is there a way to reset this?
First, I was using Mac, connected via KeySpan USB to serial. Then I moved it over to a brand-X Win2K desktop and connected via serial. Same problem. So then I tried moving it from the Carrier Board back to the BOE. Same error.
Allan,
No. I've just been going through the Robotics! book (Servos chapter 2, page 44).
Is this just a situation where we can call it "when EEPROM goes bad"? I've had this chip for over 6 months and its misbehaving now. Should I just call in for a replacement?
csavage@parallax.com
If so, it's possible your eeprom has a 'worn-out' location. Parallax may be able to replace it, if you send it back to them.
It's also possible this is a serial port error -- are you using a USB cable? Have you set FIFO's to zero on that port?
Allan,
I'm not using USB, I'm using a serial cable connected to com port 1.
