Problem with IDE 2.0.3--breakpoints not highlighted Nevermind--Solved! Doh!
I am running WIndows XP with all the latest service packs and updates. I installed the IDE 2.0.3 and I am using a Javelin Stamp version $05. But I get nothing when I click in the margin in teh IDE code display--I shoudl be able to set a breakpoint. Interestingly, the breakpoint does set (confimred by running the code) if I select breakpoint from themenu, but it never-ever highlights. I apologize if this has been covered before--did search on 'IDE breakpoint' before posting and found nothing.
Is ther another IDe I can use--this is very sub-par nto to be able to visually see breakpoints.
Post Edited (dl) : 11/7/2005 4:40:32 AM GMT
