With a BS2pe you can use I2COUT an I2CIN commands.· The trick is the addressing, but if you look on page 7 of the Microchip documentation you'll see how it's setup.· This is not a full program, but here are the elements I would use:
EE24515···· CON··· %1010
devNum·····VAR··· Nib··············' device to connect: %00 - %11
slvAddr····VAR··· Byte·············' slave address byte for I2COUT/I2CIN
wrdAddr···· VAR··· Word·············' address within EE
blockSel··· VAR··· wrdAddr.BIT15····' block select bit
The construction of the slave address looks trickier than it is; the point is to·set the device type (%1010), the 32k block select bit·for the word address, then the·the device that you want to talk to (%00 -·%11).·
Insider tip: You don't have to worry about·BIT0 of the slvAddr byte -- I2COUT and I2CIN take care of this bit for you.
If you happen to use this code in one of your commercial applications, please include credit to Parallax, Inc. (in your listing/documentation) for this bit of code.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
This chip works like two times 24LC256 in one box. The 'LC515 uses address lines A0 and A1 in the same way as does the '256. The address line A2 has to be wired high (meaning, you can only hang 4 'LC515 easily on the same I2C buss, for a total of 256k). In the control byte:
1010BAAR
1010 identifies this as a memory chip.
B is a bit that selects either the low or high segment of 256kbytes
AA is the address of the chip corresponding to the levels on hardware pins A1 and A0.
R is the read/write bit (managed by the Stamp I2Cin/out command).
In other words, the bit B is the most significant bit of the 16 bit address. The 15 least significant bits are in the two bytes that follow the control byte.
XEDCBA98 76543210
Why they didn't use the bit labeled "X" for the high address bit, I don't know. That would be logical, but that is not the way it is. You have to manipulate the B bit instead. The main consequence of that comes if your program does sequential reads. The address pointer will autoincrement up to the 256k boundary and then roll over to zero, within each 256k segment. Your program has to detect and manage crossing the 256k boundary. For block writes to the chip, the page size is 64 bytes exactly as in the 'LC256.
Tracy, I studied Jon's code above and your comments and I'm having a bit of trouble understanding everything.
For instance, Jon's code said
FOR wrdAddr = $0000 TO $FFFF
That is 0 to 65535.· The 515 has 512Kb of storage - that is 8000 pages of 64 bytes each.· I have a special requirement where I want to store some data on the last two pages of the 515 - 7999, starting address·511872and 8000, starting address 511936.· On page 7999 I want to store:
29LAHDGPR
Do you have time to show me how?
One other thing - Near the beginning of my program I wrote:
for idx = 0 to 8
serin 16, baud, [noparse][[/noparse]pt(idx)]
next
That's where the 29LAPDGPR comes from.· So....can I write:
for idx = 0 to 8
i2cdata = pt(idx)
gosub Tx_Byte
next
Hi Sid,
It is 512 kilobits of storage, not kilobytes! The chip contains 64 kilobytes. (512k/8)
There are in fact 64 bytes per page as concerns block writes. That is 1024 pages of 64 bytes. Note that the 64 byte page relates ONLY to the block write function. If you are not doing block writes, it is of no consequence in your programming. The highest address in this chip is 65535. Or, to put it another way, the highest address is 32767 in segment B.
The math in Jon's program starts with a 16 bit address, wrdAddr, and parses it so that it will select a correct 16 bit address within the 24LC515. The reason it needs parsing is what we talked about. The bit15 of the address is handled differently than the other address bits. The math shifts that bit into its proper position in the command byte.
The documentation for the part makes it pretty clear, Sid, have a look (especially at the transmission diagrams). You'll see that it only uses 16 bits for addressing (as Tracy explained above), and Bit15 of the address is stuck into the slave address byte (BIT3) -- why they do this, I don't know, but I'm sure somebody on the design team had a good reason.
devNum···· ·VAR··· Nib··············' device to connect: %00 - %11
slvAddr··· ·VAR··· Byte·············' slave address byte for I2COUT/I2CIN
Main:
· slvAddr = (EE24515 << 4)·|(blockSel << 3) | (devNum << 1)
· I2CIN·SDA, slvAddr, wrdAddr.BYTE1\wrdAddr.BYTE0, [noparse][[/noparse]myValue]
Jon Williams
Jon Williams
Post Edited (Jon Williams (Parallax)) : 11/5/2005 5:56:57 PM GMT
1010BAAR
XEDCBA98 76543210
Tracy Allen
www.emesystems.com
29LAHDGPR
for idx = 0 to 8
next
for idx = 0 to 8
i2cdata = pt(idx)
gosub Tx_Byte
next
Thanks, Tracy
Sid
·Post edited by Newed
Post Edited (Newzed) : 11/5/2005 7:58:32 PM GMT
Tracy Allen
www.emesystems.com
Jon Williams
