"failure to communicate", BS1 working but wont program
My BS1-on-SuperCarrier board is working happily away, and I want to change the program. It tokenizes, recognizes the BS1 ver 1.4, and has a "hardware failure to communicate". I'm using a desk PC with a serial cable which plugs into the little serial adapter for BS1's.
A brand-new battery (yes, tested good) does not help. When I click on "run", the lights on the board quit blinking, so I assume that the stamp has been reset, but that is as far as it goes before the disappointing message.
What to look at next? Do those little adapters go bad? Can a BS1 work but be unprogrammable? Is there a diagnostic procedure written out someplace? I searched the forum for "hardware failure to communcate" but didn't find anything.
Thanks for any & all ideas!···· -Eric
I was wondering:
Do you have "STAMP BS1" and "PBASIC 1.0" Directives at the top of your program?
The only possibly adverse thing I did was attempt to use a cheap USB-serial converter cable, to allow me to program with my laptop. It didn't work because it isn't a good enough converter to have all the lines needed for stamps included, but I have tried this before and it didn't hurt anything. I just had to go back to the desk PC and its serial port. I wouldn't think it could hurt the little serial-adapter for BS1's, and it didn't on previous attempts. If I had another serial-adapter I would test it by substitution, but it's Saturday and I don't. Any more ideas?
thanks for your time,· Eric
·· Are the little arrows lined up on the adapter with the ones on the board?· In other words, is it plugged in correctly.· The symptoms you describe can happen when one of the pins (PCI) isn't connected.
csavage@parallax.com
Also, I put in a brand-new BS1 and tried it. It tokenizes, recognizes BS1 Ver 1.4, and has a "hardware communication failure" also.
Replacing the old BS1, it happily starts blinking, blinking, blinking....I am getting mad at little computers, and I have a BIG HAMMER!
I just ordered 2 more little serial adapters from Parallax, but I hope to solve this sooner than that!
·· In the meantime, if you haven't programmed this device from this computer in the past, try disabling the FIFO buffers on the serial port.· You did say you're not using a USB to Serial Adapter on this computer, correct?
·· No, there are no settings on the adapter.· In fact, it is nothing more than a few transistors and resistors.· A complete schematic for building one can be found here (Scroll down the page):
http://www.parallax.com/html_pages/downloads/software/software_Stamp1_Windows.asp
Of course, if you have replacements on the way, you'll know soon whether it is the adapter or the BS1 that was damaged.
· -Eric
·· Have you received your new adapters yet, and has this corrected your problem?· I didn't see anything in the thread about trying these on another computer, unless I missed something.· Have you tried this?
It downloaded!
I fiddled with a few lines of code,
it downloaded again,
and again, for about an hour....
then quit working with a "hardware communication failure,"
My 2cents...
If you mean it was working fine each time you downloaded the program and then after an hour it sotpped working..
Perhaps you have too much current flowing from a pin, or a short somewhere.
Metron - The stamp has always done what it was last programmed to do. It continues to do so. What it doesn't do is communicate with the PC and accept new programs, except·when it decides it will. What I can't figure out is what determines when it will and when it wont.·It is a·BS1, supercarrier board, serial adapter, & Dell PC. So far, I've substituted a different BS1, and checked all the stuff people have suggested, and I am working on feeling really stupid when I figure it out [noparse]:)[/noparse]
· -Eric
· -Eric
