Lcd's
                    not sure if i have posted this or not but anyways.· I am working on making thermoter that tells me road temp as well as outside temp.· I have the road temp sesor i need to get the out side temp sensor but i also need to get a lcd that will show me both temps and if posible have a bar graph display to show temp change.· Has anyone done anything like this or recomend what lcd i should use?· I will use the basic stamp to drive the project jsut need some imput on componets for you guys· let me know
·· You can use the Parallax 2X16 Serial LCD Display for this purpose.· Not only can it show both temps on one line, but if you need a Bar Graph, there is an example in the Projects Forum.
csavage@parallax.com
have a look at parallax lcd section, they have some with pixel graphics capabiliites:
http://www.parallax.com/html_pages/products/audiovisual/lcd.asp
an other source (also docu & specs available):
http://www.seetron.com/slcds.htm
Regards
Adrian
Ryan
Ryan Clarke
RClarke@Parallax.com
Tim
Buy a used nokia 5160/5165 cell phone(make sure it works) and do this:
http://forums.parallax.com/showthread.php?p=555533
You may also want to check out Matrix Orbital serial interface displays aswell. We have included bar graph commands built into the modules. All you would need to place in your code is the command syntax which is outlined in the manuals. Everything is adjustable in the software, and it's easily interfacable with the Basic Stamp. There are plenty of examples with the Basic Stamp communicating with a Matrix Orbital display shown at www.matrixorbital.ca/appnotes/basic_stamp/ I would take a look at one of the displays manual like the LK162-12. This is a 16x2 character display, and the manual is located at www.matrixorbital.ca/manuals/LK_series/LK162-12/ You check out our large selection of dislays at www.matrixorbital.com/
Feel free to PM me, if you have any further questions.
thanks
mike
·· As I said, different LCD Displays have different ways to program them.· You will have to decide on one first, then worry about programming it.· Depending on the display you choose, there may or may not be programming examples out there that you can use.
www.shop-en.display3000.com/pd1127081354.htm?categoryId=0
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv37.pdf
Jon Williams
