Automatic start generator Swamp deer camp window Unit
················· Automatic start generator Swamp deer camp window Unit
·I am looking for a way to use bs2 to pull a relay to·break the solinod to
stop a starter from spinnig on a generator. I can not come up with a way to
send an unput to the bs2 when the 4cyl gas wisconson moter reaches 800 rpms.·
·I have made a device that uses a wall thermastate and a window unit and it is
run by a bank off batterys and an invertor. What it does is start a gas generator· when the thermastate temp comes up to where it is set then 2 minutes later the window unit comes on and runs till the thermastate drops 6 degrees·then the ac turns off and·1 minute later it kills the generator.
·· Every thing works great but curcit to take out the starter solinod.
I was useing a centrifical switch. Was not dependable.
··················Any·help would be Great
················································ Brewer··
You could just run the starter for a predetermined time, programmed into the BS-2. If it didn't start, try again, etc.
Good luck!··
I tried useing a relay. Generator voltage has to much lag time. It would burn the starter up if left like that for long tome use. But I am going to leave it hucked up has
a saftey backup. As for running starter for a predetermined time. Should work I`ve
just bee thinking to deep. Thanks going to try it.
PJ Allen
I did some reading on interfaceing a Tach. I am just I beginer to basic stamps.
I think thats over my head at the moment.
These are little devices that are sensitive to magnetics changes....and you attach little magnets to a turning point.
So, if you have part of a shaft that is exposed....you could attach these magnets and do a simple pulsin (with some added 'circuitry' maybe) or you could even put some reflective tape on a serpentine belt ( in multiple spots--measured distances) and then use some sort of opto/laser/IR? to read it in....
Steve
I would really want a system that cut the starter when the motor gets moving, not just crank the motor for a specified period of time. Even a small amount of delay in cutting off the starter will result in excessive wear on the Bendix gear and shaft, as well as the ring gear on the motor. I think the difference in starting temps will make for different start lengths, and that you will have to program the length for a cold day, grinding the gears on warm days.
The Hall effect sensors as mentioned above would be one way to go. Or a reflective disc on a pulley. Either way, make sure it has good enough resolution at low RPM to be able to quickley determine a start condition. If you have put together your system so far, I'm sure the tach isn't more than you can handle.
I've worked on a few generators with auto-start (I live in a rural area that loosed power for days, even weeks at a time in the winter) All of them have a sensor of some variety to determine a start condition. I hav'en't ever poked around with the innards to see how they worked.
One thing is you say the voltage rises too slowley to use. That seems odd to me, and I wonder if your gen has a circuit to prevent juice being ouput until the motor gets up to speed. I wonder if you measured right at the windings as opposed to the outlet if you would find the voltage rising. I think you would.
Just my $.02.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
