usb to serial adapter cables
Hi! I Just got my first little program working with a BS-1 on a Supercarrier board & 9v. battery. It has an eternal loop that flashes 4 LED's in turn on pins 0 thru 3. (It will ultimately be a fountain-controller.) Anyway, it works fine when I use the serial port on my desk PC, but I want to program it with my laptop which only has USB, so I sent away for the el-cheapo "Wailly" brand USB converter cable.
·The BS editor (v 2.1) which found a "BS-1, ver 1.4" running from the desk PC, reports that it tokenizes OK, but·is "unable to program BS-1 version 0.0", and to "contact Parallax for software upgrade,"·when run thru the laptop and USB converter cable. Same editor, same program, same board...
·I have checked that the com port is set to 4800,N,8,1, or whatever matches the port on the PC which does work. Is there anything else I could check before trying a different converter cable?·· Thanks, Eric
thanks for your time,· Eric
·1+1=10
Known workers are the BAFO unit (still available?) the FTDI which Parallax has standardized on, and the KeySpan 19 units. If the USB to Serial adapter is for PDA's, most likely it WILL NOT WORK, as PDA's only need TX, RX, and GND to work.
All basic stamps that I have (BS2 BSp24), Javelin, and SX-KEY
Look on ebay, you can usually find them very reasonably priced.
"OEM NMEA GPS Module" Now available on ebay for only $19.99
Product web site: http://www.allsurplus.net/Axiom/
