Making Percussion sounds with FREQOUT?
I'm experimenting with creating sounds with the FREQOUT command. I can get bleeps and beeps, which are cool.
Has anyone been able to produce drum or percussive sounds? I know it's possible, just don't know how to begin.
Thanks for any info, it's appreciated.
Tony A
Tony A
Jon Williams
an old test on questionable speakers was to put a 9vbattery across the terminals to see if the coil still worked. This would push the coil totally in one direction and would give a pop. Maybe PWM might work for you?
I'm merely thinking of the top of my head, and have not tried this....so you take your own risks!! Have ruined my own speakers in the past and it was losing a loved one!
I don't know if the stamp can control PWM fast enough that you could "force' an envelope (of a sort). -- start with one PWM value and then step down through a couple other ones to get the 'curve' Jon was talking about.
An SX might be faster for this!
It's up to you to determine what voltage you can safely put across your speakers if using this method....
Steve
I am able to produce clicking sounds that are produced at the same time as some beeps. Together it sounds pretty cool.
I should try filtering too.
You can get some very cool sounds from the stamp alone.
Thanks again,
Tony A
·1+1=10
