RF digital transmission of morse code signals
Crystalionx
I programmed a BS2 to send out a morse code signals through a piezo, just by altering the simple alarm program.· Now, I am trying to use the RF digital devices to transmit the signal from one BS2 to another.· Is this possible?· I am trying to utilize the serout/serin commands according to the instructions, but I cannot figure out what the value would be.· Any suggestions about programming the BS2 to transmit such a signal.· Thanks.
What RF modules are you referring to? How about attaching your code?
Steve
Another way, depending on the transmitter and reciver type you are using, would be to use the PWM command to pulse the transmitter input with the Stamp using "real" morse code, meaning sending long and short pulses of the standard length. Depending on the reciver, you may need to drive the piezo with a transisitor or not. This would allow you not to have to have a stamp on the receiving end if all you want is a wireless remote beeper. Tell us more and I', sure we can help.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
