Monitoring Battery Power Level — Parallax Forums
joelmanjoelman Posts: 10
edited 2005-10-31 22:11 in BASIC Stamp
How would I monitor the power level of my 9V battery using the Basic Stamp? I basically want to keep track of how much more life is in my battery.
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2005-10-30 13:34
    joelman -
    Other than checking the voltage with a voltmeter before you use it, little else makes much practical sense, since 9 volt batteries have such poor power reserve. With larger or different batteries, and/or with rechargables, a battery monitoring system would be worth the investment in money and time.
    Just one opinion.
    Bruce Bates
    edited 2005-10-30 17:25
    There's an app note on using RCTIME to monitor the Vin battery supply, at this URL
    emesys.com/BS2rct.htm#B_voltage
    Bruce, a 9 volt battery at 300 milliamp hour can last quite a long time in a project, especially if the Stamp can SLEEP, perchance dream.
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 10/30/2005 7:11:30 PM GMT
  • joelmanjoelman Posts: 10
    edited 2005-10-30 18:08
    Sweet.
    Joel
  • Tricky NekroTricky Nekro Posts: 218
    edited 2005-10-30 18:43
    The best way is by using a 555 timer...
    Here's schematic and program...
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' First started by TronicGR, later modified by Provas.
    ' For
    www.Greekbotics.tk
    'Variables
    coefficient·· VAR·· Word···· 'AD555 math var
    adc555······· VAR·· Word···· 'AD555 input values
    result······· VAR·· Word···· 'AD555 calculated float-point output
    volts········ VAR·· Word···· 'AD555 true integer output
    LED·········· CON·· 1
    DO
    ·· PULSIN 2, 1, adc555········
    ' DEBUG DEC adc555, CR····
    coefficient = 27499······
    volts = coefficient / adc555
    result = volts *100······
    volts = adc555 * volts···
    coefficient = coefficient - volts * 10
    result = volts * 10 + result
    result = volts + result
    result = result + 250
    ·· DEBUG CLS, DEC result," = volts * 100",CR
    ·· IF (result < 800) THEN blink_Led
    ·RETURN······································
    LOOP
    blink_Led:
    HIGH LED
    PAUSE 100
    LOW LED
    PAUSE 100
    RETURN
    Greece, Provas
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
    Post Edited (Provas) : 10/30/2005 6:53:00 PM GMT
    edited 2005-10-30 19:18
    -Rule your Destiny-
    edited 2005-10-30 19:20
    I think, "Best Way" is a relative/subjective term which may apply differently depending on the given circuit/power/layout considerations.· I guess what I am saying is that we cannot offer the "best" solution, only possible solutions and the user has to decide what works best for him/her.
    csavage@parallax.com
    edited 2005-10-30 19:56
    I found that spacing in the ascii art at emesys.com/BS2rct.htm#B_voltage had been thrown off somehow, so I just went in and corrected and republished it. Agreed, "best" is a relative term. In some cases, a simple "low battery" threshold detector is all that is required. At the otherr extreme, it has to be accurate to microvolts and only a high resolution ADC will do the trick.
    Tracy Allen
    www.emesystems.com
  • steve_bsteve_b Posts: 1,563
    edited 2005-10-30 20:20
    There was an article (not on this pc) that described using a lamp (@rated voltage) and a CDS photocell with RCtime.
    The orginal use was in a solar panel system, so the user wanted to be sure to isolate the measuring device from the charging system....
    They enclosed the lamp and the photocell in a 'dark' box and used a lookup table I think to determine voltage levels.
    You could also use an A/D converter or if you just want to know when the voltage drops to a certain amount you could use a voltage divider that equates to a logic level....."many ways to skin a cat"
    Steve
    edited 2005-10-30 21:54
    This subject came up recently in another thread....
    Here is a link to a thread that I posted quite some time ago on the L.O.S.A. (List Of Stamp Applications)
    http://forums.parallax.com/showthread.php?p=548418
    Beau Schwabe
    IC Layout Engineer
    edited 2005-10-31 02:04
    Hi Provas
    And every one else
    Please look at PM· Provas
    I have to ask you something
    Sam
    Sam
    I've received the pm...
    Please check yours, too...
    I'll upoad some files, hoping to help you as·much as I can...
    Friendly, Provas, Greece
    -Rule your Destiny-
    Post Edited (Provas) : 10/31/2005 10:17:23 PM GMT
