DS2760 reports 32 degrees
Hello , my DS2760 will only display 32 degrees on the debug terminal, have cleaned k/ leed in wires and even tried running· program to get id codes from the one wire device. Have also tried
pluging in the id to see if that would work. I have two DS2760's so I dont think it is a hardware problem. Also is there a way to send the temperature readings from the BS2P24 to my BS2 so that I can plot them with my stamp plot pro? I am using my BS2 to monitor temperatures on a waste oil heater, and would like to be able to plot·and monitor the exhaust and combustion chamber temperatures using the thermocouples, Thanks David B·
csavage@parallax.com
