Gripper Kit
Hiiii everyone
I want to ask you abou how I can buy "The Gripper kit #28200", and if I can use it in my project, in controlling it by a computer wireless for gripping and moving the kit, I know that this product chang by The Gripper kit·#28202, but I dont know if I can use it to be controlled wireless??
please help me···
please help me···
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
So, must buy the Gripper kit #28202, and the RF module ( only the reciever or reviever & transmitter )??
but I coudnt understand if this kit contained a microcontroller???
please give me a detailed information since am reading the documentation but I couldnt understand several things<<<
http://www.parallax.com/html_pages/products/communication/rf_modules.asp
Dave
Dave Andreae
Tech Support
please I need a clear idea about this product.
The gripper kit is an accessory, just like many accessories that Parallax already sells. Accessories are intended as "add-on" parts to an already existing, or planned electro-mechanical platform. Since I can only guess how its motion mechansim actually works, just take the following as one way that it MIGHT work, NOT that is DOES WORK this way.
I've seen a number of gripper accessories which use an R/C servo as the motion mechanism. Therein, with a PBASIC Stamp you issue ordinarly PULSOUT commands to open and close the "fingers". The PBASIC Stamp is mounted on the central platform, and not on the gripper accessory itself.
This is NOT to say, that some other microcontroller. CPU, or other quasi-intelligent or programmable device, other than a PBASIC Stamp, might be the "brains" issuing the appropriate commands to effect the R/C servo movement, by issuing the appropriately timed pulses and any necessary pauses. as may be·required for the R/C servo to move. The method used to operate R/C servos via timed pulses and appropriate pauses is well documented on the Internet.
Bruce Bates
well, what is the central PBASIC stamp? and if I get the PBASIC stamp I dont need to purchase a microcontroller??
·· For a fully-functional Robot with Gripper you would need the following items:
BOE-Bot Full Kit:
http://www.parallax.com/detail.asp?product_id=28832
Gripper Add-On:
http://www.parallax.com/detail.asp?product_id=28202
And if you need wireless, check this link for Bluetooth...
http://www.parallax.com/detail.asp?product_id=30068
csavage@parallax.com
But why BOE-Bot Full Kit:
I want a robot which is moving and has a gripper to pick things>
The robot base, wheels, motors, battery holder, etc. are what makes up the "bot" part of the BOE-bot.
The Basic Stamp, and protoyping board make up the "BOE" part of the BOE-bot.
The full·BOE-Bot kit gives you everything that you need to have a programmable mobile robot platform.· It includes a great teaching guide as well.
Once you master·the programmable mobile robot platform, you can then move on to·more advanced things like grippers,·etc.
OR
get the gripper kit then get PBASIC stamp to make the gripper "move and grip"??
Post Edited (Ayah) : 11/2/2005 10:25:05 AM GMT
The BOE (with a stamp on it) is the brains.
The bot is the legs.
The gripper is the hand.
And the wireless module is the walkie talkie.
If you want all of these functions you need to get the BOE-bot, gripper and wireless module.
If you don't want it to move around, you dont need the bot part and you can just buy the BOE and youll have a stationary "hand" that opens and closes when the wireless module tells it to.
If you dont want to grab things, you don't need the gripper, and you'll have a mobile bot that can move according to the wireless module.
If you don't want remote control of the bot, you don't need the wireless module, and you'll have a bot that can move around and grab things according to the program stored in the BOE.
The only thing nessesary in all circumstances is the BOE (brains).
Your fundamental confusion indicates you noviceness (nothing to be ashamed of, we all get our start sometime), but it would be best for you to learn how to walk before you attempt to run. Before investing all the money into buying everything and quickly getting in over your head, I would suggest you first buy just the BOE-bot. Follow all the exercises that come with it and get yourself familiarized with how it works. Then once you've done that, buy either the gripper or the rf-module then learn how to integrate that with the BOE-bot, then finally purchase the last component and integrate that as well.
·1+1=10
If you are doing this for a school project, I think your instructor will understand that it will take some time. I don't think you will find an easier way to get results than by following Parallax's curriculum, in the order suggested by Chris Savage above. Essetially. all you have to do is buy the kit, open the box, and follow the instructions. If you haven't bought anything yet, download and look at the books to see what's involved. And if you aren't old enough to easily follow the suggestions given, ask a parent or teacher for help with the project.
Can I get an answer about why you are included a wheels to the gripper kit if I should using BOE-bot??
Post Edited (Ayah) : 11/3/2005 10:44:45 AM GMT
I am not trying to be rude in this post, but am being blunt in hopes of helping you understand.
If you look at the page and documentation for the gripper kit carefully, you will see that wheels are not included. The Gripper kit is shown in the pictures attached to a BOE-BOT for illustration purposes only. The page states that the Gripper is meant as an accessory for the BOE-BOT, which is sold separately.
Once again, as has been repeatedly stated, you will need the following:
BOE-BOT kit: This is the basic robot, including wheels. This included the microprocessor and breadboard (STAMP chip and BOE [noparse][[/noparse]Board of Education] development board. It also included all the parts to make the robot function, as well as instructions and sample code for programming.
Gripper Kit: This is ONLY the gripper, and meant to be an "add-on" for the BOE-BOT. While it could be purchased for other uses, the mouting brackets, etc. are specifically designed to attache to the BOE-BOT. The only parts included are those for teh actual gripper itself. No wheels, no microprocessor, no nothing except the parts for the actual gripper, and brackets to attache to the BOE-BOT.
Remote Control: There are a number of possible options, including Blue Tooth, IR, etc. There are specific products mentioned in other posts.
You can wish things were different all you want. You can ignore the advice and information that you've been given all you want. The net result is that you will still need all three of the above to do what you have asked how to do. For some reason, it seems that you don't believe what is being said here, and it looks like you're trying to tell people who have worked with these items, including people who work for Parallax, that they don't know what they are saying. I think the posts here, and the information on the Parallax web site are actually pretty clear. You need to take some time and READ the information presented, not just look at the pictures. From your discription of the project you want, you seem like an intelligent person. You just need to slow down, take a good look at ALL the information available on the web site, and take the advice of those who have been around this a while, and try not to challange so much those you ask advice from.
Perhaps the project has become unafordable or more complex than you thought. The facts are not going to change. You seem to be acting like it's unfair, and that people are lying to you. This is really not the case. You have asked some good questions, and then not wanted to believe the answers. The answers are the answers, and are not going to change.
John R.
8 + 8 = 10
One of the problems with a text only forum, is that we can only guess what the spirit of any post, including mine is meant to be. I didn't mean any offense, just wanted to "jolt" a little that the information here is good.
On the page you reference, look at the "center panel" of page one (labeled "Fig #1". The drawing, and 'Parts List' clearly show what is (and by omision what is not) included.
The rest of that manual shows how to "apply" the gripper to the BOE-Bot, as the kit is specifically targeted at users of the BOE-Bot.
I don't mean to be a jerk, but the information is there, and seems clear to me. Just slow down a little, and read more carefully.
John R.
8 + 8 = 10
but in this situation the budget of the project become expensive
Post Edited (Ayah) : 11/6/2005 9:02:50 PM GMT
~Jeff
P.S. This is what this part of the alphabet would look like if "Q" and "R" were eliminated.
BEN
@ blimp
It probably would have been better to start a new thread and link to this one if you wanted to, but anyway, I'll answer:
You won't find it, you write it.
You'll have to think through your particular setup, and figure out what you want it to do and how to go about it. I like to sit down in a closed environment (in class, on the bus/train, church, etc.) with a piece of colored paper and I scribble my ideas and project design on it. Usually it hangs around for a couple of days before making it into the trash, but the important thing to get here is that you have to make some sort of plan for your project.
You won't be able to get a complete, working solution, but you will probably be able to get pieces of code that you can integrate into a single solution. My guess is that your gripper is servo powered: so write a routine to open the grip, another to close, and another to hold. Write a routine to receive commands from your wireless. Write a routine to send commands wireless. Write a routine to get user gripper commands or generate your own. Put it all together.
