Trying to find a good text for VisualBasic-->Stamp programming
Hello Stamp Forum readers,
I've been working on a project that involves using my computer in conjunction with my basic stamp. Obviously this will involve communication between the computer and the stamp and I'll have to write a VB app to trade data and directions, etc. I'm a new VB programmer and I really need a great info resource for this specifically. I'm sure this is a well-trod path and I know I'm going to need to do this a lot for the kind of ideas that I have. Can anybody point me to a text or something so I can really crack down and develop this programming technique the right way?
thanks,
Taylortronic
p.s. parallax rocks!
thanks,
Taylortronic
Here is about the "simplest" example (<--It has to be that way for myself) of a PC talking to a Stamp using VB4...
http://forums.parallax.com/showthread.php?p=549166
Scroll towards the bottom for the Visual Basic code, the top contains the Stamp code (you will need this) and Quickbasic code.
When I initially "GOOGLE'd" for an example to help me out, the application was for receiving RS232 signals into Visual Basic via the "RS232.Input" function.
After playing around with it a bit I discovered by trial and error the "RS232.Output" function which allowed me to communicate to the Stamp.
Beau Schwabe
IC Layout Engineer
It has VB examples that you can LOOK at.
http://www.parallax.com/html_pages/downloads/software/software_stampdaq.asp
It contains a working VB program, with source.· It also includes a text file, which tell you how to regenerate the VB program using the VB IDE.· It contains a very simple BS2 code to send out a byte once every so often.
Now, you also have to know that the BS2 RS232 hardware will echo everything sent to it -- so you'll have to remove the echo'ed characters from VB before you get the BS2's response.
It's really not complicated enough to deserve an entire book, though.
thanks again,
taylortronic
