Digital Inclinometer — Parallax Forums
ShamsulShamsul Posts: 2
edited 2005-10-27 15:17 in Robotics
I am trying to build a digital inclinometer. My idea is to connect a linear potentiometer to ADC0831 then connect to SLED4C (or three 7segment LCD). When the voltage from the potentiometer is zero then it will display 0 (Zero) again the potentiometer will rotate, it will supply 1.5V to ADC the SLED4C will display 210.
·This is my first project with ADC0831. Would you please tell me, what are the things I should buy? Would you please tell me about the connections and the program? I know the BASIC program.
·Thanks
Shamsul
shamsul@shaw.ca
Vancouver
  • Tronic (Greece)Tronic (Greece) Posts: 130
    edited 2005-10-27 12:48
    Why with ADC0831? Why not keeping it simple? With a simple RC circuit
    and 3 lines of code you can read inclination fast and easy. In my solar tank
    project I mounted a weight on the axle of a 10k pot so it can follow gravitys
    direction. Then just measure the time it takes to discharge the 0.01uF cap in
    various angles and there you go you can have as many detail in angle
    detection as you need. In Tank I used only two angles, those that was dangerous
    to flip over trying climb a obstacle or when backing up towards a wall...
    inclined VAR WORD
    forwd: ' forward movement routine
    DO
      HIGH 11
      PAUSE 1
      RCTIME 11,1, inclined
      IF (inclined > 550) THEN
        GOSUB brake_servo
        GOTO backwd
      ELSE
        pulseRight = 650
        pulseLeft = 850
        GOSUB Send_Pulse_ramp
      ENDIF
    LOOP WHILE (continue = 1) AND (inclined < 550)
    Post Edited (Tronic (Greece)) : 10/27/2005 1:29:32 PM GMT
    the photos show the new compact design versous the huge one prototype
    that the video shows.
    Click below to watch the video with the inclinometer sensor in action.
    http://media.putfile.com/inclinometerdemo
    Post Edited (Tronic (Greece)) : 10/27/2005 1:51:20 PM GMT
  • BeanBean Posts: 8,129
    Of even better, use the Memsic 2125 accelerometer.
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    Available now... SX-Video OSD module $59.95 www.sxvm.com
    Life is NOT a box of chocolates.
    Life is a trip, and 99% of the time you get where your headed.
