ping sensor help!! — Parallax Forums
ping sensor help!!
RontopiaRontopia Posts: 139
edited 2005-10-28 05:05 in BASIC Stamp
I have a boe bot and just bought a brand new shiny ping sensor. I carefully entered the example code for the bs2 in to my editor. problem is the syntax checker seems to have a problem with some of the syntax. I have searched the boards and found nothing helpful.
here is a copy, the syntax checker is having a problem with the "Main:" statement. just for kicks I commented it out. The syntax checker then had a problem with the "DO" statement.
any help would be much appreciated
thanks
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
Ping PIN 15
[noparse][[/noparse] Constants ]
#SELECT $STAMP
#CASE BS2, BS2E
Trigger CON 5
Scale CON $200
#CASE BS2SX, BS2P, BS2PX
Trigger CON 13
Scale CON $0CD
#CASE BS2PE
Trigger CON 5
Scale CON $1E1
#ENDSELECT
RawToIn CON 889
RawToCm CON 2257
IsHigh CON 1
IsLow CON 0
[noparse][[/noparse] Variables ]
rawDist VAR Word
inches VAR Word
cm VAR Word
[noparse][[/noparse] Initialization ]
reset:
DEBUG CLS,
"Parallax Ping))) Sonar", CR, 'Setup Report screen
"======================", CR,
CR,
"Time (uS).... ", CR,
"Inches........ ", CR,
"Centimeters... ",
[noparse][[/noparse] Program Code ]
Main:
DO
GOSUB Get_Sonar
inches = rawDist ** RawToIn
cm = rawDist ** RawToCm
DEBUG CRSRXY, 15, 3,
DEC rawDist, CLREOL,
CRSRXY, 15, 4,
DEC inches, CLREOL,
CRSRXY, 15, 5,
DEC cm, CLREOL
PAUSE 100
LOOP
END
[noparse][[/noparse] subroutines ]
Get_Sonar:
Ping = IsLow
PULSOUT Ping, Trigger
PULSOUT Ping, IsHigh, rawDist
rawDist = rawDist */ Scale
rawDist = rawDist /2
RETURN
Muahdib
IC layout designer
Phoenix Arizona
    edited 2005-10-27 04:33
    The problem is that you have a hanging comma at the end of the line that says "Centimeters" (just ahead of Main[noparse]:)[/noparse] -- doing this the compiler thinks that it should be seeing a constant or variable value, not a program label.
    Jon Williams
  • RontopiaRontopia Posts: 139
    edited 2005-10-27 04:43
    you rock
    thanks
    I will be back to let you know how it comes out
    Muahdib
    IC layout designer
    Phoenix Arizona
    edited 2005-10-27 04:57
    there was one other problem but I would not have got this done without your help.. so thanks.. your a man among men[noparse]:)[/noparse]
    I have one other question. do I need to use a resistor on the sig connection of the sensor itself? if so what size?
    thanks for your help
    Muahdib
    Muahdib
    IC layout designer
    Phoenix Arizona
    edited 2005-10-27 05:29
    No, there is one onboard.
    Jon Williams
    edited 2005-10-27 18:17
    thanks again.
    do you know where I might find some example code for using ping sensors on my boe bot to roam with? I have some ideas but it helps to see some code to start with. Im new to any kind of programing... if you cant tell[noparse];)[/noparse]
    Muahdib
    IC layout designer
    Phoenix Arizona
    edited 2005-10-27 18:33
    I don't have any -- but I'm sure other forum members do.
    Jon Williams
  • metron9metron9 Posts: 1,100
    Code examples links at bottom of page
    http://www.parallax.com/detail.asp?product_id=28015
