Help with BS2 modem connection
I'm new in using the BS2. What I'm trying to do is to connect an old modem to my bs2 interface board and have the modem send out an SMS to a cellphone. I think·I know how to communicate with the modem, but I'm unsure about the connections that I need to make. I'm using an old US robotics modem. So far I did the following:
- connected pin 5(gnd) from the modem's serial cable to vss
- connected pin 3(tx) from the modem's serial cable to pin 8
I tried to·have the modem dial a number by sending the ATD command to the modem something like this:
serout 5,84,[noparse][[/noparse]"ATD12345"]
Obviously, nothing happened.
I'm not at all sure this is the way to go. ANY help would be appreciated.
I'm sorry for my crappy English.·'cause I'm Dutch, it's not my first language.
Thanx in advance.
Thanx in advance.
·· Nowhere in your connections did you mention connecting anything to P5 on the BASIC Stamp.· Even if you did, the modem will be looking for RS-232 levels, and the TTL levels from the BASIC Stamp will not work.
As a side-note, you might have better luck connecting the modem to the DB9 on the Dev Board you're using.
csavage@parallax.com
Ofcourse you're right. I made a typo in my post. The code that I actualy used was:
serout 8,84,[noparse][[/noparse]"ATD12345"], since i connected my tx lead to pin 8. (At least, that's what i intend to do
BTW, i'm actualy using an USB board with my BS2, so there is no DB9 connector on my board as far as I can see.
Beside that, the end result for this project is to use a stand-alone BS2 with some kind of OEM GSM module. (probably·from Siemens)
Because I don't have that modem yet, I'm just trying it with an old serial modem.
Is there anyone who can supply me with some documentation about the physical connection's that I should make?
Thanks!
·· So now I see two possible problems...First you'll be needing a driver, such as a MAX232 for the RS-232 signal levels.· Second, you will need to connect to the modem's RX line to transmit data to it.· I think you're trying to connect TX to TX, when in fact, generally speaking, TX on one device connects to RX on the other device.· Of course, this all depends on you know which pins are really connected where!· :P
I missed the ttl - RS232 part.
About that: I'm under the impression that there was only a small diffrence in these signals? I mean, RS232 being about 3.2 volts or something and ttl on 5?
I also tought that this only beeing an issue when using longer cables? The cable I'm using is only 30cm long.
I'm probably all wrong about this, but please consider that I'm new on all this.
·1+1=10
The modem uses a higher voltage than my bs2 is capable of delivering, so I should use some kind of converter (max232) in order to get this to work. When the modem is 'talking' back to me, the voltage is to high for the BS2, so I can use a resistor to correct this.
Instead of the max232, isn't it possible to use a transistor in combination with an external power supplie in order to·get a higher voltage to the modem?
Your comments are greatly appreciated. (or however that may be spelled
You are right. As·I mentioned before, I did not completly read your reply before I answered.
So, if I am going to·use a transistor to 'boost' the current, is that all there is up to it? I mean, is it only a matter of incorrect current or are there other issues that·I need to be aware of? ··I'm thinking of using a pin to open the base of a transistor (by using·a resistor) ·and·connect·the TR's output to the RX pin of the serial cable.
This is all just for the prototype of my device. In the final version I'm going to follow your advice and·use the max232. I attached a datasheet for such a chip, could you tell me if·this is what you·have in mind?
Thanks!!!!
·1+1=10
That's kind of hard to understand for me. I think I get it, but I'm not sure.
I should probably use the max232 then. The one from the attachment any good?
Bummer for me that I have to wait for 5 days before I can get this chip...
Are there any scheme's (?) / documentation·available for connecting this chip to my BS2?
Thanks again.
Someone once explained the thresholds to me...but my take was that a logic 0 (typically +12Volts in rs232) can still be read in 0 to 5v levels by the +5 as it's enough over the threshold to trigger.
The logic 1 (typically -12Volts in rs232) is still read too as it's under the threshold....
I've found some things can still work....something to try first anyhow.
Steve
Today I received the max232 I ordered. Much to my suprise btw, normaly this takes over 5 days.
Anybody out there who has a diagram on connecting all this technology?
Thanks a lot for all the reactions!
Greetings,
Tom.
And if you want to learn more about transistors you can start here http://hyperphysics.phy-astr.gsu.edu/hbase/solids/trans.html
·1+1=10
