Servo control Via VB6
Hello all,
I have a quick question, I need to send data from a VB app to a Basic Stamp 2 on a BOE however I'm having difficulty. The main question is - when I use the SERIN command is that taking the data from the Serial port intergrated onto the BOE or is it the other DB9 connector thing intergrated into the middle of the board? This might be confusing but please bare with me I've just begun working with Microcontrollers.
Over all what I'm trying to do is send a command from a VB6 app out the serial port (MSCOMM API) to the basic stamp to control some servos. I'm wondering if I need to get a serial cable and modify it for that DB9 input in the middle of the board or if I can use the DB9 connector used to upload programs and such into the stamp.
Any help would really be appreciated
Thanks - Jon
Thanks - Jon
·· That's not a serial port in the middle of the board, it's an AppMod connector.· When you program the Stamp Module you're already connected to the BASIC Stamp, so why not just leave the cable connected?· Then you can send commands that way.· If you're just sending one-byte or two-byte commands this should be sufficient.· If you need more bandwidth consider using our RS-232 AppMod.
http://www.parallax.com/detail.asp?product_id=29120
csavage@parallax.com
Ryan
Ryan Clarke
RClarke@Parallax.com
