Resister LED...
On this schematic, the power supply shows a resister LED, I was just wondering why it doesnt designate the resistance or voltage for the LED. Dont they come in different resistances or am I confused?
http://www.parallax.com/dl/docs/prod/schem/2440BrdSchem.pdf
- Matt
- Matt
It is a led with an internal resistor, usually meant for 5v logic circuits...
Bob N9LVU
- Matt
·· Resistor LEDs come with resistors for certain voltages.· That is, you can buy an LED rated for 5V and you can also buy one rated for 12V.· There's no reason to know the value of the resistor, since it's designed usually for a specific voltage.· Knowing that the one in our circuit runs off 5V, you simply buy a 5V LED.
csavage@parallax.com
It's not the resistance, it's the supply voltage that the led is going to be used with that is important..
I think that in the schematic "Resistor Led" means a led with an internal load resistor...
Also some leds can be used with a wide range of dc voltage " 5 - 12", as they have an internal
dc regulator plus a resistor....
I have both types, and some of the variable voltage leds are also flashers...
Bob N9LVU
