Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Power connection — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Power connection
Nubs
3
2005-10-25 05:01
edited 2005-10-25 13:40
in
BASIC Stamp
What pins do you connect power to on bs2.
allanlane5
3,815
2005-10-25 13:40
If you are using the on-BS2 regulator, you connect plus 6 to 12 volts DC to the Vin pin, and the ground line to Vss.
If you have an external regulator, you connect plus 5 volts DC to the Vdd pin, and the ground line to Vss.
Do NOT connect +6 volts to the Vdd pin, you'll burn out the BS2.
You CAN connect +5 to the Vin pin. It won't work, but it won't damage anything.
Sign In
Register
to comment.
