Question concerning PDB and high output driver current.
Can someone tell me how much current a Parallax PLC can handle when driving it's outputs? I want to interface it to a 24V-DC Latching relay and will be Pulsing the· output to drive the relay. Also, will I need to install a protection diode since the outputs I believe are optically isolated?
JMLStamp2p
JMLStamp2p
·1+1=10
·· As per the manual, the outputs of the PLC are controlled by a chip inside which is listed in a table on the last page of the docs which tells the current handling capability of that chip.· There are three configurations available, so you should double-check.
csavage@parallax.com
