LCD Help Please...
I finally got my LCD working but then I had to remove the stamp from the topboard in order to fix something. I then put it on backwards and noticed nothing worked. I then realized my mistake and put it on correctly but now the LCD doesnt work.
1. How can I diagnose if I fried the LCD?
2. Is there some diagnostic program that can test the stamps outputs to make sure none of them are fried?
3. Is there a way to protect the LCD from reverse polarity or other screwups? I imagine it only needs to be VSS and VDD that have this protection, maybe VBT which is 3.0v should be protected too. I have no idea how to do this.
Matt
Matt
Sid Weaver
Do you have a Stamp Tester yet?
- Matt
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Most serial displays will perform a self test if the data line is grounded. Check the docs to see if that is true. However, since you inserted the Stamp backwards, I doubt if the LCD saw reversed voltages, so hopefully it should be OK. Try the LCD on other pins or another Stamp. Even if the i/o pin will light an LED there can be problems with serial comms, especially at higher speeds. I have seen this personally on a Stamp abused in class. Took a while to get it working.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
A hefty diode on the power supply to the LCD will protect it for a while until it blows. A better way is to limit the current to the LCD with a resistor of the correct value to allow the LCD to function, then select a diode that can handle that current indefintley.
Jonathan
Jonathan, regarding your comment on limiting the current, I thought it would only draw the current it needed regardless of what the supply current is?
- Matt
·· That is true...The LCD will draw only the current it needs.· If this unit is not backlit, it should be 10mA or less.· In any event, if something's connected wrong/backwards the current it "needs" can go up significantly, toasting something.· By the way, it isn't clear from your first post whether you put the Stamp Module in backwards or the LCD?
csavage@parallax.com
I put the PDF spec on the LCD in one of my prior post but cannot find it. The Part is OSD2002BYPNJB
- Matt
Also, is this thread related to: http://forums.parallax.com/showthread.php?p=553896
Post Edited (Chris Savage (Parallax)) : 10/22/2005 6:44:02 PM GMT
