Basic stamp controlled Robosapien via IR
Got my self a nice Robosapien v1. planing to create a IR transmitter that would be able to live transmit comands from my Mac via keyspan adabter and a stamp BoE, using MACBS2.
Have any done a similar prosjekt? My questions are: The modulation part I understand, but the actual "message"? how is it written in basic code? does anyone have a code exemple I can look at? the site[noparse]:http:[/noparse]//www.andrew.cmu.edu/user/ebuehl/robosapien-lirc/ir_codes.htm is on this subject, but Im not very experienced in basic stamp an ir comunication..
stig
stig
Intially there was a big interest in hacking the Robosapien, but after that fell off the publications seem to have moved on to other projects. You might start a group on Google.
Here's a place to start . In this example, the serial connection is hard wired into the IR sensor connection on the RoboSapien board, but there is no reason it couldn't be done with the IR link. The example is on a microcontroller with a 4 MHz clock. similar to the Stamp 1, so you will need to convert Pulsout commands to Stamp2 timings.
http://users.bigpond.net.au/robert_gatt/robosapien/robosapien.htm
