The 0831 is a 1 channel sensor...So you would need 1 0831 per sensor.· Because it is a serial interface, you need a clock signal, DataIn signal, and Chip select.
The only problem I can see using a different family ADC is that if he doesn't know how to calculate for the different resolution, he could have trouble with the math, which is necessary to use this sensor properly, since the output is non-linear.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
Sid Weaver
Do you have a Stamp Tester yet?
Sid Weaver
I've attached a demo program so that you can see the programming differences between the ADC0831 and ADC0834.
Jon Williams
