Using keyboard input for BS2 — Parallax Forums
agentileagentile Posts: 101
edited 2005-10-20 16:34 in BASIC Stamp
Hello,
· I would like to know if there is a way to·interface my BS2 to my computer so that I can have the BS2 read input from the computer's keyboard while a program is running.· Is there a command for reading the computer's keyboard?
thanks,
agentile·
  • NewzedNewzed Posts: 2,503
    edited 2005-10-19 19:15
    Type
    SEROUT 16, baud, [noparse][[/noparse]"Enter command", cr]
    debugin com·· 'Type an A
    The debug screen will say
    Enter command
    A
    If you want to send a string to the debug screen declare
    serstring var· byte(8)
    Then instead of debugin write:
    SERIN 16. baud, [noparse][[/noparse]serstring\8]
    You willl have to enter 8 characters - no more, no less.
    For more info see the Help file.
    Sid Weaver
    Do you have a Stamp Tester yet?
  • agentileagentile Posts: 101
    edited 2005-10-20 13:56
    Sid,
    · Thank you.· This is excellent.· What I want to do is to use the BS2 as a calculator using the keyboard as an input.· This project is intended to demonstrate·the limitations of non-floating point arithmetic, and also to·underline the importance of·accurately sizing variables.· Anyway, since we are only entering numbers and operators (single characters), it seems that with a little manipulation of the inputs, this project will work out well.· Thanks again.
    agentile
    P.S. Do you know of·any examples of this type of code available in the archives?
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2005-10-20 14:14
    Is there anyway to cost effectively interface it with a PS2 keyboard (stand alone). I know using a USB keyboard would require a USB chipset and hardware programming to interface to it. Just curious if anyone has done this.
    How about interfacing to a SVGA monitor (The closest think I have is the SX video module which is pretty cool in itself) - but I am guesing this would require much more hardware (e.g. video card interfacing that may be too much for a single BS2 chip).
    edited 2005-10-20 14:26
    You might try this: http://www.awce.com/pak6.htm
    Jon Williams
    edited 2005-10-20 14:34
    People have also reported success using the ezKey http://www.multilabs.net/ezKEY.html
    Some people have kicked around the idea of a svga monitor driver, but I haven't seen someone discuss completing the project.
    ·1+1=10
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2005-10-20 14:57
    FYI:
    If you can find an old UNIX SUN-workstation keyboard, the output is RS232 (5V levels) 1200 baud.
    Beau Schwabe
    IC Layout Engineer
  • Donald BartleyDonald Bartley Posts: 19
    Besides the Multilabs ezKEY they also have color video modules www.multilabs.net/Products.html that you could use to make an on-screen calulator.· Even cooler would be to use their ezMOUSE with the ezVID 2.0 which has a floating character to make a pointer.· Then you could just draw the calculator on the screen and the user could move the pointer around on the screen and click on the numbers and operators on-screen.· tongue.gif
