BS2px as Frequency Divider
Hi, has anyone tried to build a Frequency Divider with BS2px and following characteristics:
Inputs
Impedance ....100k Ohms
Wave form ....Sine, Square or Pulse.
Freq. Range ..0.5Hz to 1Megahertz
Level ....... 3.0V min. 0.5Hz to 1MHz
············· ·.25V min. 2Hz to 200kHz
············· ·.1V min. 10Hz to 50kHz
Output
Impedance ....<200 ohms
Level ........5V P-P, Square Wave
Freq. Range ..Input frequency divided by integer steps from 1 to 9,999.
I need to have 4 switches to set divider.
Thanks for your help.
Kova
Inputs
Output
Kova
·1+1=10
and I wanted to see if BS2 can do the job. If you have any schematics and/or code for SX it would be a great help. Thanks in advance,
Kova
I don't know what level of experience you have, and Ive thrown out alot of terms in this post, ask and I will·explain anything you don't understand.
Another thing, how are you going to specify a range for N to be 1-9,999 when you only have 4 switches (16 states)?
·1+1=10
Post Edited (Paul Baker) : 10/21/2005 1:57:07 PM GMT
market. I need to build DAQ for 8 strain gages, 2 load cells, 6 RTDs, 8 TCs, 2 vibration sensors and 2 freq. inputs. Those frequencies are to high for my tape recorded, so I needed that divider to be able to record them. A mounting rack that is available for my DAQ is very small, so I had to look for something portable. However, this is not the end of my idea to use BS2 for this test, so I'll check what I can do to take a sample readings from "analog streams" (as faster as possible) with BS2 and save them on USB drive with USBWiz. I know this is to much work for only one BS2 so I'll try Master/Slave communication between those two. If you have any ideas/schematics/code for this I'll appreciate it. Sincerely,
Kova
