Looking for a simple dual H-bridge....
for DC motors.· Does anyone have a good homebrew dual H-bridge that you have used.· I need to be able to switch 5 amps back and forth...reversing, and it needs to be dual.· I can build two of them if you have a good single H-bridge.
I do use the L293e alot, but it is only good for 1 amp, and I have build H-bridges using relays for "slow" reversing as in wheeled robots.
Deno
Deno
Stuart
Thanks for the reply...deno
Never mind...I found it and thanks again...deno
Post Edited (deno) : 10/20/2005 10:42:38 AM GMT
For different type of contol:·serial /RC puls/analog
http://www.solutions-cubed.com/solutions%20cubed/MM1_2005.htm
Rob van den Berg
