Question on Current...
I thought someone told me a long time ago that a circuit will only use the current it needs and if the source is greater then that is good. Is this true? If I use a wall wart that outputs 500mA at 9v and feed it into an LCD that takes 100mA will I blow the LCD or will the LCD only draw the necessary current?
What got me questioning this is that the spec sheet for the LCD says:
symbol = ldd
condition = Vdd=5v
Min = -
Typ =
Max = 100 mA
And I began to question what I had learned since if it only "drew what it needed" then it wouldnt make sense to have a 'Max' current...
Someone please straighten me out on this elementary concept. Thanks.
- Matt
symbol = ldd
condition = Vdd=5v
Min = -
Typ =
Max = 100 mA
- Matt
·· Yes, you were right the first time.· Current ratings of devices reflect what the device needs/draws.· Current ratings on supplies tell what the supply can produce.· The 100mA is the maximum·current the LCD will draw/require so your 500mA supply is fine.
csavage@parallax.com
Jon Williams
Many unregulated DC devices produce higher voltages when using less current.
Since voltages generally apply to the ability to insulate a circuit [noparse][[/noparse]called 'breakdown voltage'] often a solid-state device will experience an excessive voltage condition even though it is not drawing much current. Most devices will easily tolterate a 10% over-voltage, but beyond that is risk.
The real culprit here is the labling on the cheaper wallwarts. If in doubt, check it with your multi-meter to see that it is not producing a no-load voltage in excess of your devices maximum voltage. At the maximum load it comes down to the expected voltage.
When in doubt, use a battery [noparse][[/noparse]and check that too as some fully charged ones are over the top]
