5v Supply Circuit
I am looking to make a 5v supply for my LCD. I have found two ways of doing it.
1. Use a 7805 with CAPS to stabilize current surges
2. Use a LM317T Variable Voltage Regulator IC
I am new to this, I am sure both would work fine but which is the way an experienced electronics guru would use? or is there even a better way?
- Matt
- Matt
Jon Williams
1. Are the capacitors between VIN and GND and then again between VOUT and GND to keep a constant/steady voltage and current as the circuit fluctuates a load?
2. When and LED is shown in a schematic like that and just says "Resister LED" what kind of LED should it be? I know they come in different voltages, etc. Would I assume a 5v LED?
3. Is the output current the same as whatever the input current is?
Is there a resource for looking up schematic symbols? I am new to this and I notice just on the BS2 Demo board schematic there are two different symbols for Caps. One is parallel lines and one is a line with a smile face next to it.
- Matt
2. That's a component designed for 5 volts -- you could safely use a standard green LED and a 470 ohm resistor (will consume about 7 mA -- use a bigger resistor to reduce the current [noparse][[/noparse]LED will be less bright]).
3. The output current will be whatever your circuit consumes, up to what the regulator and input supply are capable of providing.
Jon Williams
This thread has an image attachment at the bottom of one of Guenther's posts that shows a circuit to use with a 7805:
http://forums.parallax.com/showthread.php?p=546903
Here's a thread where questions about resistors and LED's are adressed in detail:
http://forums.parallax.com/showthread.php?p=548249
I wonder if this wire is hot...
