Exponential formula
I am working on a project that uses PWM to power a Tachometer Guage.
The movement requires 200 mv to read 8,000 RPM, and 100mv to read 4000 RPM so the voltage is linear
I have experimented with PWM using a 4.7k resistor and a .01mf capacitor
I use 12,500 us on time and 10 mS off time to get 200 ma and a reading of 8,000 RPM
at 4000 us on time and 10 mS off time I get 100 ma and a reading of 4000 RPM
So to sum up I am using a constant off time of 10mS on time from 0 to 12500 us for voltage readings 0f 0 to 200 ma
What is the math formula to calculate any voltage from 0 to 200 ma for the on time value?
0=0
4000=4000
12500=8000
0=0
4000=4000
12500=8000
For ease of calculation, assume the graph really is a straight line.
Then rpm = (m * "on time") + offset
where m = 0.47 (by calculation)
offset = 2000 ( by drawing a graph, rpm on x-axis, "on-time" on horizontal)
example: when on-time = 8000 uS
rpm = (0.47 * 8000) + 2000
= 3760 + 2000
= 5760
when on-time = 10000
rpm = (0.47 * 10000) + 2000
= 6700
If the curve really is non-linear from 0 to 4000 uS, the calcs for curve fitting may be beyond the Stamp. But, you may be able to use a lookup table.
Cheers
Tom
You might want to take some more readings to find the true nature of your system. Curve fitting can be tricky with a BASIC Stamp, but as our pal Tracy Allen has shown severall times, it's not impossible.
Jon Williams
